Copy configuration and log files from an external USB device to the internal Flash memory.
  1. Enter Privileged EXEC mode:
    enable
  2. Copy configuration or log files from the USB device to Intflash:
    copy /usb/<srcfile> /intflash/<destfile>
Switch:1#enable
Switch:1#copy /usb/test.cfg /intflash/test.cfg
The following table defines parameters for the copy command.
Variable
Value
<destfile>
Specifies the name of the configuration or log file when copied to the internal Flash memory. The destination file name must be lower case and have a file extension of .cfg or .log. For example, test.cfg or test.log.
The file name, including the directory structure, can include up to 255 characters.
<srcfile>
Specifies the name of the configuration or log file on the USB device. For example, test.cfg or test.log.
